Help us build an awesome import updating system
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,252
We are working on functionality that will allow users to update imported files while preserving the edits that they made on Onshape. This will be useful to those of you who work on CAD systems in addition to Onshape or collaborate with people who do.
For example, say a user imports this model and then edits it on Onshape:
If the user updates the import to the new file below, our goal will be to find the appropriate correspondences between faces, edges, and vertices, and transfer all the Onshape features (as well as mates etc.) to the updated model:
We would like your input on what types of updates should be handled. What are the most frequent types of changes you make on imported files? If you can, please post pairs of models (original, updated) which you think our correspondence algorithm should be able to handle.
Thanks!
For me the biggest thing would be assembly mates as I try to create additional design as separate parts around imported model to keep them separated and make it easier to update the import as needed.
But if there will be such functionality, I would most likely drill some holes and create cut-outs to make models fit each other.
It would be amazing if you could recognize duplicated parts somehow, for example roller conveyor with 50 identical rolls (with 100 bearings, 100 dust sleeves, 100 M8x20 bolts etc.) simple conveyor can be easily 400 parts on import though there is only 15 different parts..
To answer your question:
Features to automaticaly update into new version of import:
Part studio
- sketch (position and geometries created with 'use' command)
- hole
- cut-out
- fillet / chamfer
- boolean
- transform
- pattern
- color, material & part descriptions
Assembly
- mates (also group)
- position (fixed)
From - to images about type of changes to apply automatically in assembly:
It would be perfect if we could create versions or configurations from imported models, so that it could be possible to easily compare different setups without repeating same work for each imported model.
I don't know how Onshape 'sees' imported models but I suppose we could also teach it by clicking few corresponding faces or so..
Unfortunately, we can't rely on successive imports coming from the same "seed" file because every CAD system has its own special super-secret way of keeping track of which face is which (Onshape is the only system where this is partly exposed through FeatureScript queries).
So what we're doing is some amount of geometry matching. Longer term we'll want to have a way for the user to help this identification, but for now we're focusing on an automatic method, and looking for examples to test on.
@3dcad
Yes, if we can identify matching vertices/faces/edges, all of the things you mention would automatically update.
Don't forget to recognize backported features in your automatic method (eg I go back to the original part and add the chamfer in your example part, because I added those during a live design/ECO review in Onshape and they need to get reflected back to the 'master' design.)
How are you thinking to regocnize which import should replace old one as update and which is just another import?
The import tab has an "Update" option in its context menu. Currently it creates a new part studio, but the idea is that it would replace the old import instead. If you want a new import, just upload to a new tab.
What if I have used imported model in multiple assemblies or multiple copies in single assembly and I only wan't to update some of them (I'm thinking standard components)?
Are you planning to support also imported (step) assemblies where can be dozen sub-assemblies, main assy and a single part studio with all the parts?
Yes, but possibly not for the first release. Details there are fuzzier.
we develop electronic designs, printed circuit boards (pcb), which we have to integrate in a construction (standard housing, 3d print, ...) for what we use os. if we print, the part will be also made in os.
so we export the pcb from the design program (altium) as step and import it in os. earlier thread about this: https://forum.onshape.com/discussion/comment/18079#Comment_18079
seldom we have to manipulate it separately in the part studio tab - it is simply not the idea (as your example at the begin suggests).
most often, the imported step consists of several parts which has to be grouped first in a subassembly.
then it will be placed in an assembly together with the housing and mated (dark green: pcb).
slider mate (on the right) into the housing:
check if front panel (separate part studio, outline imported, cuts in os) fits:
after, an iterative process can start:
- make chances where possible on the housing and front, means in onshape ever (standard housing and 3d print)
- make modifications on the pcb when necessary, means in an external app (altium). --> that is when the whole work starts again: import, group, mate! would be great if this could be fastened and less boring.
additionaly there are more mates in the assembly (here on the yellow part) where other parts depends on the imported one (dark green: pcb):
replacing the imported step, at close at the source as possible, would be fine.
best, ml
Meanwhile the SWX base part has had some minor changes and I want to update the model without losing the direct edits I have already made. I read your thread and was delighted to hear you are proposing an 'update' option in the import tool. However when click the '+' button in my studio the subsequent dialog box does not offer this option. Was it ever implemented? Am I looking in the wrong place? - Thanks in advance
Twitter: @onshapetricks & @babart1977
OwS.
HWM-Water Ltd
IR for AS/NZS 1100
Feedback on how well we preserve references to imported parts is welcome.
