Rib-type axial cam
I found another thread on barrel cams but my question is a little different. I need to model an axial cam for two cam followers. Unlike the groove-type barrel cam, it will have a raised rib with a follower on each side - sort of the inverse of a grooved barrel cam. This a a bit more complicated in that the width of the rib must change with the pressure angle whereas the groove-type barrel cam groove width is always the same. The advantage sought is that the cam followers can be pre-loaded axially resulting in a very quiet, smooth running cam.
Anyone have an idea of how to do this? I know there are very expensive software packages for modeling cams but I only need to do it once.
bill_daniels Member Posts: 278 ✭✭✭
You're right. The contact points (actually lines) are not parallel nor is the angle between them constant except at two points 180 degrees apart. These cams are made and used in industry so there must be some way to model them.
5
