Can ANSI holes be exported to STL?
I've created a test plate with 1/4in 20 through holes and selected "tapped". When I view the STL file the holes
NeilCooke Moderator, Onshape Employees Posts: 5,848
By specifying a tapped hole, Onshape is calculating the drill size and applying that to the model. If you want the actual thread for 3D printing then you will have to model it yourself using a helix and a sweep.Senior Director, Technical Services, EMEA5
