Using Tabs
stevehessstevehess Moderator, Onshape Employees, Developers Posts: 98
edited August 2014 in Using Onshape
A quick tip, drag the tab you want to be the default tab on open to the left most position (the first tab) in your workspace.
Steve Hess \ Onshape Inc.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,094 PRO
    That's a good one.
  • rajendra_bhatrajendra_bhat OS Professional, Mentor Posts: 8 ✭✭
    Also, if you want switch between 2 tabs which you are working, can use Shift + right mouse button click on tab then release shift and select back/ forward
    Remember you can hit ? to see our keyboard shortcuts....
