Google Chrome WebGL Problem
Tobes49
Member Posts: 3 ✭
Over the weekend my computer was reporting -
I
tried my laptop and this all works perfectly
On
the non working computer, I tried reinstalling chrome and the Graphic drivers -
this didn't cure the problem
http://webglreport.com/
- reports:
Ive done some searching the testing - checked the flags in google and they all look correct
Chrome://gpu
Click here for report States Webgl is hardware accelerated but has lots off memory errors at the bottom
Now
Ive tried 5 computers now and 3 are fine and 2 don't work (They all did work
before)
The
2 that have packed up had the Nvidia 342 update before this happened. (Not sure if this is the problem or not)
I
have uninstalled all the graphic drivers and this still has not cured the
problem
Can anyone help with this please?
Toby
Target:
--disable_chromium_framebuffer_multisamplePlease remember that the fix is then only applied to this specific shortcut. If you have multiple shortcuts to Chrome (for instance both in the start menu and the desktop), it will only work for those you have edited. Give special thanks to øyvind_kaurstad because this solution provided by him.https://forum.onshape.com/discussion/4963/onshape-suddenly-reports-webgl-is-not-enabled-in-chrome-is-this-a-bug#latest
Thanks for the info
- What version of Chrome and Operating system are you using?
- Are the versions of Chrome the same on the computers which are working and the ones which are not working?
- Can you paste the errors you are seeing?
There has been a recent bug in Chromium and here is the Chromium bug report : https://bugs.chromium.org/p/chromium/issues/detail?id=656989 . You may want to check if this is the same as what you are experiencing.
While we figure out the issue, please consider using another supported browser such as Firefox or Safari.
Ive been doing some more testing and think it is the Chromium bug, (It has only effected my computers with Nvidia graphic cards for some reason?)
PC is Core 2 Q8400 with windows 10, Chrome is 54.0.2840.99 m, Nvidia GeForce 8400GS
Chrome were different versions - all started to happen when the Nvidia updated to version 342.00
Error just appears at the top off the "loading workspace" page with "It looks like your browser doesn't have WebGL enabled"
I have downloaded the chrome canary edition with this installed everything works again.
Then enable "Override software rendering list".. The nice part about Chrome Canary is it can be installed side by side with another chrome channel (stable/beta/dev)
