Importing Assemblies
Mecha
Member Posts: 7 ✭
1) I noticed when importing a moderate size X-T assembly, all of my parts ended up stacked in a single location. It makes it really difficult to use it, with every imported part in a common origin.
2) I noticed when importing surfaces, they get translated into the part studio, but not the assembly. they are not considered parts at all and the geometry cannot be used.
If sending CAD is SW, open your assembly then click save-as sldprt, all components. You can then save the part file as a parasolids and bring it in or just import the sldprt. That's how I got my SW geometry into Onshape.
Bill described one viable option of saving a SW part file from a SW assembly. And this is a viable option. However Onshape actually will do this for you if you select the option flatten uploaded assemblies as part studios.
File this under nifty workaround
LearnOnshape facebook group
M
How hard is it to rotate geometry 90 degrees about X while translating it? There's gotta be a function for this? Hopefully. Should be one line of code attached to one checkbox.
I don't think a simple view manipulation will be enough.
Hi Bill, if you are addressing my response I'm not talking about a view reorientation but actually reorienting the default coordinate sys and default datums to be Y is up verses Z is up.
M
Sorry, I didn't intend to demean your comment. Sounds like you want to move the root coordinate to the geometry and I want to move geometry about the root coordinate. I think we're on the same page.
OS please don't change default view with 'Y' up. This is what I should have said.
