Clarification in licensing please
kevin_quigley
Member Posts: 306 ✭✭✭
in General
Just reading through all the forums and blogs now and I came across this on Develop3D:
To clarify the statement: “you get five free projects to work on before you need to start paying”... With Onshape you get as many documents as you like for free. With the free plan, you can simultaneously access 5 documents. It does not change their privacy or limit, only what can be accessed at the same time.
Up until this time it was my impression under the free plan you could have as many documents as you want (up to a file storage limit) but only 5 could be private. So am I misunderstanding this as that comment seems to suggest you can (say) create 100 private documents on Onshape Free, but only edit 5 at a time?
So the question is then, setting aside the file size limits why would you pay? I only edit 1 document at a time now. My perception of the free/paid thing was that you could only HAVE 5 private documents, and any extra you created were public. Whilst you could change documents from private to public to retain the 5 private ones, you had to make that choice. Is this not the case?
If you can now create 100 private documents then this changes the landscape for the use of Onshape Free quite dramatically.
The "Onshape Plans" video on this page http://www.onshape.com/product-tour explains the differences in the plans.
suggestion...and one I have mentioned before...would be great to tie into something like Dropbox so we could sync Dropbox content to an OnShape document, or possibly utilise unused Dropbox space as an Onshape archive for older files?
I can see once OS is used in anger I will quickly hit the '5' limit as I compartmentalize projects and assemblies and figure out how to link documents together. Or will linking documents by sharing assemblies and parts between documents slow things down - speed and stability wise? Will it be better to keep whole projects in one document?
Can OS give a steer on what way to proceed and what to look out for in terms of file size/component number/complexity? I know there will be no fixed rules but after working for a while one gets a feel for these things. Any steer would be helpful.
Regards
Jon
Jon
However, I'm wondering how the '5 active documents' model will hold up once you start cross-referencing parts in different documents.
Could become confusing to the user.
Dries
My dad runs a small metal workshop. Stairs, interiors, gates... you name it. Just occasionally he would benefit from a CAD tool for more complex and intricate jobs. Or when customers expect a pretty picture on their quotation.
Onshape will be PERFECT for him (when drawings are released).
Dries
For a personal anecdote, when I graduated college I wanted to continue using CAD to model, design, and build up my portfolio but my options were limited. I had been using NX in school with a student license that I wasn't supposed to be using once I graduated and I didn't have a mechanical job directly out of college. The result was I had no system to model on and my options were to buy a personal license (expensive and scary), pirate/steal a copy (morally opposed), or go CAD-less (easiest least ideal). I essentially went a couple years without doing any CAD, opting to go pen and paper for my personal projects, when something like the Onshape Free plan would have been perfect for me. This is why I am so excited for our Onshape Free plan.
Jonathan_Stedman said: We are designing Onshape with the idea that you can keep everything related to the document in that document, but that doesn't mean it is the only way to do it. I expect our users to explore and determine what is the best workflow for them and design that way. We should be encouraging diversity in design and not pigeon hole you down a certain path.
Jonathan_Stedman said: On my test account, I've been a user since July and have used between 10 and 15GB of data with about 200 documents. However, the size of documents vary based on the number of tabs in them, whats uploaded, how complex the part studios are, etc. My best suggestion would be to use the system and periodically look at your account details via Manage Account and check your storage used. You can best estimate based on your goals and workflows how much storage you would need.
That said, of course there'll be exceptions, and I am confident we can satisfy those customers.
I imagine the 100GB limit today might be irrelevant in 2 years time.
Bring on quantum storage!
Dries
I would imagine with OS's versioning, you don't need to copy versions to different folders creating a non-linear expansion of data usage.
I guess I don't see 100GB being an issue.
So think about this for a moment. 12 years worth of data that needs to be accessed. That is (looking at the hard drive pile) around 2.5 TB of data (of varying sorts).
At 100GB per user, does that 100GB follow the Dropbox ethos of when you share a file that file gets added to your usage? If so that effectively means 100GB per company. That is nowhere near enough guys.
what bothers me is this. I start now at $100 a month for 100GB and in 5 years Im needing to access 1TB of data. How much will that cost me....for every single user account?
Sorry these are important issues that need answers.
So questions:
