mouse wheel direction
Can we flip the zoom of the mouse wheel to mimic the other CAD\CAM systems we use?
1
mcconnell113 Member Posts: 74 ✭✭
len_1962 said:So it is in the works?
not sure I understand the second part.John McConnell - Let's change things.
Saplingstore.com5 -
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,012
@len_1962 There are a number of requests that come in for preferences. It was not put in the product since at launch since there are many options that need to be thought out. With scroll the feedback is immediate and you can quickly correct it. As @Andy Morris has mentioned, we will eventually add a profile that will roam with you no matter what you are on... Windows, Linux, Chromebook, Mac.. Glad to see you in here bud.
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.1
This is an interesting (but solvable) challenge since you'd want the scroll direction to be the same on which ever device you sign in on, without having to change the operating systems setting each time i.e. 'natural scrolling' on OS X.
Saplingstore.com
I only use Windows with SW and HSMWorks, surfcam every day and the mouse wheel is a pain, makes me not want to learn Onshape, sorry
trying to use it a little bit more, 120 senior deign students and the Formula team has kept us pretty busy this semester.
Thanks,
Randy
well it is a pain when you are going between 2 to 3 different programs where 2 use the mouse the SW way and then then other is bassackwards.
Don't even get me started about Rhino
I just had some hypermesh training, their mouse controls are atrocious too.
But keep it up Onshape feels like it's a combo of NX and solidworks, my 2 favs.
So now that this has been implemented, can it be made so that the "Reverse scroll wheel zoom direction" option is tied to "Environment profile settings", rather than "View manipulation".
As the "Environment profile settings" are tied to a specific device, I presume this change would allow me to set the scroll direction on a per-device basis.
Since I use the trackpad on my MacBook and a mouse scroll wheel on my PC, I'm currently having to go into my preferences to change the scroll direction every time I switch between devices in order to have Onshape behave the way I like.
Thanks,
Andrew
You could also change your trackpad settings or use pinch to zoom?
