How do you mate flathead screws to their countersinks?
lee_carter
Member Posts: 11 ✭✭
Options3dcad Member, OS Professional, Mentor Posts: 2,470 PROHow about using a single fastened mate at the midpoint where cone turns into cylinder? That would also update on depth change but user would be responsible for matching cone angles on screw and hole. (I borrowed your image Bruce)
//rami8
I would use a Fastened mate and offset down on the Z until the screw is approximately the right position
Or Alternatively a combination of Cylindrical and Tangent mates for positioning perfectly to the counter sunk hole. This will show position and change if the screw or counter sink size changes. Maybe the better option but it takes double the mates.
