Any way to fillet the corner of a surface?
song_jaybi
OS Professional, Developers Posts: 17 ✭✭
OptionsTimRice Member, Moderator, Onshape Employees Posts: 315As Bruce mentioned, you could use a split face/part feature to make a cut in the surface. You could then use the delete face/part feature to remove the unwanted portion. A little cumbersome, but should work!Tim Rice | User Experience | Support
Onshape, Inc.5 -
Optionsviru Member, Developers Posts: 619 ✭✭✭✭@song_jaybi, Yes your method is fastest and best method. I Forgot to include this method in above video.
5
I am looking forward to a suite of surfacing tools, solving some simple problems would be a great start.
Onshape, Inc.
I also hope to be developed a suite of surfacing tool.
Viru, your sample is very good!!
I think this way is faster than your example.
At the split phase
select type: Face
Face to split: Surface 1
Entities to split with: Sketch 3
Now, This way is best for me.
Thank you.
