Create dimension tangent to 2 circular lines?
Hello,
I cannot find a way to put a dimension on the drawing which is tangent to 1 or 2 circular shapes. See screenshot what I want to achieve.
What is the method to achieve this?
Johnny
Johnny
As shown in my attachment the radius of the two circles plus the vertical distance between the two centers of the circles already equals the total hight dimension you are trying to create. If you want to add that dimension just for visual reference then I would suggest creating two construction lines and making them tangent to the circles as shown in my attachment and then add your dimension. Hope that helps.
https://cad.onshape.com/help/Content/sketch-tools-dimension.htm
Be sure to check out "Driven dimensions" at the bottom of the page to learn about the difference between Driven and Driving dimensions.
Driving dimensions appear black and can be edited.
As a workaround you can split the face or add a small bit of geometry in the part studio, at the place you wish to dimension from, this will then enable you to select a node with the 2 point linear dimension tool in the drawings.
Forget my workaround above.
