How can I use planes to mate parts in assembly? --- I figured it out!
I'm an experienced SW user and I often model my parts with the plan of using one or more of the planes as a mating feature in the assembly. I'm having a tough time figuring out how to simulate this in OS. I can't figure out how to place the mate connector on my part so it will act in place of a plane.
Update... Here's how you do it: When in a part studio, you can place a mate connector on the origin. But you can't pick the origin from the model tree, it has to be showing in the model space and you have to pick it there. It is sometimes a pain to grab it. You have to hover on it just right. When you have picked it the "origin entity" box will say "Vertex of Origin". Then if you want you can realign using a plane. The planes can be picked from the model tree. You can't do this until there is at least 1 solid in the model or the mate connector will not have an "owner part". This mate connector can now be used in an assembly the way you would use the planes to mate in SW.
Also, in an assembly you can mate directly to the assembly origin only by hovering on it in the model space. The orientation of the mate connector will shift around as you hover on it so you have to pick it carefully.
here's some other posts on this
https://forum.onshape.com/discussion/5050/why-is-the-ability-to-use-and-mate-to-the-planes-used-in-part-construction-missing-in-assemblies
https://forum.onshape.com/discussion/5652/is-it-possible-to-display-planes-for-mating-purposes-the-part-is-an-imported-rexroth-extrusion
https://forum.onshape.com/discussion/comment/22813#Comment_22813
https://forum.onshape.com/discussion/4517/how-to-mate-a-spring-in-assembly
Maybe the OS creators want to explain their thinking here. I thought all experienced SW users liked mating with planes when possible so it seems weird to me that OS would not do this.
Thanks again brucebartlett, I'll keep trying to find the best way based on your explanation.
In my normal workflows rather than mate parts to the origin, I drop a part into assemblies at the default original studio position and fix in position (by click the tick rather than clicking in the workspace) which mostly works for me but do feel this is an unsafe practice. If I remove the fix and move the part I now have no way of getting the part back to it's original when no mating geo is available. Sometimes to solve this I will drop another instance of the part (dummy) in at the origin, fix the dummy, fasten mate the original part to the dummy moving back to its origin, then delete the dummy and mate and fix the original before it is moved.
OnShape fan.
