How to import mates in an assembly?
grace_ding
Member Posts: 1 EDU
NeilCooke
Moderator, Onshape Employees Posts: 5,986
Hi Grace, when you say import a project, did you export it (download) to your computer then use the upload button? When you do that you are stripping out all the features and exporting just the solid. If you want to use an assembly in another Document, create a version in your source assembly, then in the target document use insert (in an assembly) and browse to your source document.Senior Director, Technical Services, EMEA5
