Do Sheet Metal Parts Export to DWG /DXF?
I can not figure out (google did not help) how to export a sheet metal assembly into .dxf parts. Is this even available, or am I just blind :wink:
Thank you,
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,908 PRO
    If it is the flat pattern as a solid see this post: https://forum.onshape.com/discussion/comment/26708#Comment_26708
    They say comming soon.
    Otherwise the work around is to right click the flat pattern and create a drawing
    then export the drawing
    CryogenicMinerCryogenicMiner Member Posts: 6 EDU
    The right-click-drawing option does not give a vector output, does it? Nothing that I could use to laser cut, waterjet etc. right? It is just the visual drawing for help in machining, or am I missing something. Thanks for the tip about solid parts.
    Thank you a lot!
