Complex assembly with fixed parts has become misaligned with the origin and XYZ axes.
bill_daniels
Member Posts: 281 ✭✭✭
When I built this assembly, I was careful to fix the frame with respect to the origin and align it with the XYZ axes before using mates to add literally hundreds of other parts and sub-assemblies. However, somehow, it is now rotated a fraction of a degree about the Z axis and displaced 100 mm or so from the origin. The frame still shows being "Fixed" and the added parts appear to be correctly mated relative to each other.
Short of building the entire assembly again from scratch, (two days work) what can I do to get it aligned again?
I would link the assembly but I have removed the fixes attempting to get it realigned.
