Circular pattern fail
                    Pictured is the face pattern I'm trying to solve. Had no problem with the bigger
 one above this smaller one. I tried several attempts using different axis of patterns also. Being told that the "pattern could not be created on the same part". Why does the bigger one work but not the smaller one?
 one above this smaller one. I tried several attempts using different axis of patterns also. Being told that the "pattern could not be created on the same part". Why does the bigger one work but not the smaller one?                 0
Perhaps this thread could be of help, it might have to do with intersecting geometry.
CIRCULAR PATTERN DID NOT REGENERATE PROPERLY: PATTERN COULD NOT BE CREATED ON THE SAME PART
