How To Bulk Edit Properties For Multiple Parts
eric_lau
Member Posts: 17 ✭✭
Hi Guys,
I have seen some tutorials that show a bulk edit properties screen, usually when creating a new version, but I can't seem to figure out how to get to this screen. When I try to edit properties I have to click through each part one at a time.
This is the screen I am talking about:
john_mcclary
Member, Developers Posts: 3,980 PRO
@eric_lau For things like description etc. try using OpenBoM, it will give you an "excel" style spread sheet you can modify, then push back to the parts5
You're nearly there.
(a) Click the arrow (to the left of the magnifying glass icon) to expand the tree.
(b) Use shift-select or control-select to pick the multiple parts you wish to bulk change. (In the example I'm changing the PN for my nuts.)
(c) The yellow flags indicate changes that are not committed yet, so be sure to hit apply or save. (Save will close the window if you're done, or apply keeps it open if you have more things to change)
Hope that helps,
