Thicken problem
I am definitely a newbie. I was hoping someone could help me with the correct way to do this. I need this last thicken command to merge with the vertical sections. Any guidance is greatly appreciated.
https://cad.onshape.com/documents/d743c00c5d0280081c17a887/w/921af3b720571e9e23f39e84/e/2f5e608ccc1284e73359ec46
Looks like you can't "Use" the thickened edges when looking at the part normal to the sketch plane.
I was trying to draw a filler triangle on the front plane, then revolve it, it works but you have to fake it by fully dimensioning the triangle filler with a little trig (or eyeball it if your evil
Honestly you may have to put in a ticket using the feedback tool. To let them know about this "bug / oversight". Not allowing the use of edges/verticies of the thickened face.
Sorry
projektowanieproduktow.wordpress.com
I'd say Replace Face, and Delete Face on the overhang, results in the same thing as michal_1 does I think. Same for the top end.
Tip: Get your sketches fully defined. Some of your circular edges seem to be concentric, but aren't really. if this wasn't your intention, make sure you constrain things properly so you don't run into trouble later. Also, use the sketch function Use (project/convert) for referencing previous sketches or features.
This would all be a lot easier using revolve.
@john_mcclary Use won't work, but Intersection does.
