roll tape
Dear mister OnShape, i want to make a roll tape with the helix tool, but it can´t select mi circle face, just works on extrude, can you help me to make my roll tape
i would apreciate that a lot
Thanks, best regards to you mister OnShape
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    To make a helix, you need a cylinder face to select.
    The simplist way is to extrude your circle as a "surface" to the height of your helix.
    When you say "roll tape" I imagine a spiral instead of a helix. OnShape doesn't have a spiral tool yet, but someone may have a featurescript that makes spirals.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    You could create a conical surface, create a helix, then afterwards create a sketch and "use"
    the helix.
    the helix.
    Sneaky way to create a spiral, like it!
    @NeilCooke
    I don't think i unierstand. Can i see an example?
    edited April 2017
    @john_mcclary
    I wanted to try it so forgive me butting in.
    Here be:-
    https://cad.onshape.com/documents/d51ecfd36f3d4a30b03c1f21/w/b167d8936840aa422688480a/e/3d71b72c2d6614dce2e37afc
    (1) Extrude cone
    (2) Helix on cone
    (3) Use/Project helix onto new shetch.
    edited April 2017
    @eric_mendez336 The example document above now has some "tape" with the addition of the sweep of a line to make a surface and then a thicken of the surface.  (This seemed more robust than a solid sweep of a rectangle.)
    Ah a cone :)
    He said conical surface.. so i thought he was showcasing the new conic sketch command. lol
    Thanks @owen_sparks for clearing that up
    Its nice to know helix can be wrapped around more than just cylinders. Good job OS
