Dimensions in Assembly
scott_caskeyscott_caskey Member Posts: 53 PRO
How do you add dimensions or measure distances between parts, clearances, etc., in an assembly??
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,958 PRO
    https://www.youtube.com/watch?v=iz5-X77JlJU
    this will show everything you should need to know
  • scott_caskeyscott_caskey Member Posts: 53 PRO
    This explains the measurement part, but it appears  you cannot add dimensions to an assembly?
    That is correct, You can only add/edit parts in a part studio. If you need to reference parts in an assembly, use "in-context"
    @scott_caskey - if you want to set the distance on a slider mate (for example), click the mate in the instance list and the dimension will appear on screen - you can click and edit the dimension, but it does not fix it. To set a fixed offset in a fasten mate (for example), you can edit the mate and modify the offset or you can edit each individual mate connector and add offsets to those too.
