Fill command
but to be specific am new for onshape and i am modeling simplified room layout for CFD simulation as shown in the pic below
so i want to cover the ceiling and the floor with surface so which feature can do the job?
There are workarounds involving for instance thickening or splitting that will work when the face to "fill" is planar but I'm not aware of a fully general method that currently works.
extrude:
split:
delete face:
Thanks Neil,
how can i merge or join several surfaces on same plane together and how can i cut through the surface?
tanks
