Fill command
Anwar_EAnwar_E Member Posts: 4
Hello everyone
where can i find surface fill command?
tanks
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,237
  • Anwar_EAnwar_E Member Posts: 4
    tanks ilya_baran for the Answer
    but to be specific am new for onshape and i am modeling simplified room layout for CFD simulation as shown in the pic below
    so i want to cover the ceiling and the floor with surface so which feature can do the job?
    Ah, I thought you meant something else.  That tool is currently under development and will hopefully come out soon.
    There are workarounds involving for instance thickening or splitting that will work when the face to "fill" is planar but I'm not aware of a fully general method that currently works.
    extrude, split & delete face.
    extrude:
    split:
    delete face:
    Create a sketch on the floor (using "use") then create an offset surface of zero - quickest way.
    edited April 2017
    Bingo! that's a new one:
    Thanks Neil,
    Hi
    how can i merge or join several surfaces on same plane together and how can i cut through the surface?
    tanks
