Surface
Anwar_EAnwar_E Member Posts: 4
Hi guys
How can i merge or join several surfaces together?
and how can i cut through a surface?
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,093 PRO
    edited June 2018
    @mbartlett21
    I like your opBoolean feature, seems like OS's boolean should work with surfaces (sheets). Have you thought about writing a true surface trim feature that allows you to pick the sheets to delete/keep? You're splitting them nicely. Just wish I could define the ones I want to keep using one feature script.
    Currently it's confusing to have to split and delete sheets for trimming. It'd be nicer to have a true surface trim feature script that would allow you pick targets & tools, and then pick the sheets you want to keep. Hoping there's a selection that'll return where on a surface you picked, and with that, the user can pick the sheet bodies they want to keep.
    billy2 said:
    @mbartlett21
    Maybe using vertices?
