Revolve around Document or Object Access ?
ethan_roschethan_rosch Member Posts: 5
I'm trying to rotate a portion of a sketch.
When using the rotate tool, it asks me what axis i want to rotate around.
I really want to rotate around the objects own center point Z axis and/or the origin Z axis (as the object is aligned to the origin).
If I'm understanding this correctly, I need a sketch line or part line to revolve around.
Steps would be:
  1. Create a plan that bisects the desired rotation object
  2. draw a vertical line which I want to rotate around
  3. go back to the object and rotate around that new line
Does this seem the correct workflow?
Thanks
Ethan
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,969 image
    Hi @ethan_rosch you should be able to sketch the line in your profile sketch. If not the method you mention will work.
