Can't access Offset Mate using Fastened Mate
devon_sowell
Posts: 52 ✭✭
Hello All-
I can't seem to access the Offset Mate dialog box using Fastened Mate, it doesn't display. Any tips?
Thanks in advance,
Devon Sowell
Thanks in advance,
Devon Sowell
Devon Sowell
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
760 809 9046
It will be added in a future update. We held it back because we didn't think the implementation met our standards for quality and user experience at the time, not because we didn't think it was something that should be in Onshape.Ace_Deuce said:jramlsey said:This is a screw up on our part. This is a feature we were hoping to have ready for the last update but decided that it didn't fit the level of quality and user experience we intend for so we've decided not to release it yet.
Sorry for the confusion.
Just a comment, but offsetting a face of a part from another face in an assembly is basic. I shouldn't have to create a mate connector that is offset from a part just to achieve this. That just adds clutter to either the part tree or the assembly tree. I hope this feature (the offset check box in fastener mates) gets added soon. Other than that, the assembly process has been great.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Interesting, I've never seen that offset check box. Makes sense though, better than offsetting the Mate Connector although that may have other benefits if changing mate type.
It's in the help, https://cad.onshape.com/help/#mate-fastened.htm updated the 9 of march. So I must be doing something wrong
I tried starting a new doc, I still don't see it. Onshape any idea's?
Bruce the Mate Connector can be offset? I'll try that
Devon Sowell
760 809 9046
CarlsbadCAD Carlsbad,CA0 -
I just tried to Offset a Mate Connector in the Part Studio 9in along the Y axis and I got an error message & the Mate Connector was Red in the Tree.
Devon Sowell
760 809 9046
I've been using the offset mate connector feature for this type of mate. Don't know why your's isn't working, but it's worked on all my tries so far.
-Jim1 -
Sorry for the confusion.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
jramlsey no worries, thanks for the information
Devon Sowell
760 809 9046
Devon_Sowell: Can you let us know what error you are seeing in this case when you hover over the yellow mate connector in tree or dialog? In some cases if you are creating mate connector using sketch entity you will have to select owner part if system cannot determine owner part from the selected entities.Devon_Sowell said:I just tried to Offset a Mate Connector in the Part Studio 9in along the Y axis and I got an error message & the Mate Connector was Red in the Tree.
1 -
Hello Malay-
The error message disappears when I try to <Shift-Print Screen> the message says
"Mate connector 1 did regenerate properly: Cannot resolve entities." The Mate Connector is red as you can see. I picked the origin part. I'm still learning so perhaps I'm doing it wrong?
Thanks
Devon Sowell
760 809 9046
Just a comment, but offsetting a face of a part from another face in an assembly is basic. I shouldn't have to create a mate connector that is offset from a part just to achieve this. That just adds clutter to either the part tree or the assembly tree. I hope this feature (the offset check box in fastener mates) gets added soon. Other than that, the assembly process has been great.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
I understand the importance of maintaining the level of quality of your product, but I expect this feature to be released soon, because it is important for our use.jramsley said:This is a screw up on our part. This is a feature we were hoping to have ready for the last update but decided that it didn't fit the level of quality and user experience we intend for so we've decided not to release it yet.
Creating a mate connector with move command is quite handy, coming from Alibre I had made a dozen of planar mates for building a simple kitchen cabinet. It felt somehow clomsy so I forced myself to read manual and get into mate connectors - now same cabinet has 4 fastened mates, brilliant.
@LouGallo One question about moving mate connector, how do you know directions for x, y and z and what is positive/negative value direction without testing? First I assumed it's using global coordinates (which are visible on the cube at all time) but it's not..//rami0 -
The mate connector graphic has RGB (x,y,z) axes associated to it when you inference one. The offsets are in those directions.3dcad said:@LouGallo One question about moving mate connector, how do you know directions for x, y and z and what is positive/negative value direction without testing? First I assumed it's using global coordinates (which are visible on the cube at all time) but it's not..
The blue/z axis is always made normal to the face it is inferred from (outward facing), aligned with an edge, or aligned with the center of a cylindrical face.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com2 -
Good one @jramsley , I will have to etch that into my memory, RGB = XYZ, is this any where else in Onshape?
You can see it on the view cube as well as the measure graphics (i.e. highlighting a length/distance delta in the measure area).BruceBartlett said:Good one @jramsley , I will have to etch that into my memory, RGB = XYZ, is this any where else in Onshape?
RGB = xyz is pretty standard for CAD as you'll see it in SolidWorks, Solid Edge, Inventor, and NX.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
@jramsleyI've never really taken that much notice, normally I would just look for the xyz notation, however colour is probably already subliminally locked in my though, I'll take note from now on.0
