Exploded views
3dcad
Member, OS Professional, Mentor Posts: 2,470 PRO
I have kind of special requirements for exploded views and I would like to see what other users need from this feature (that most likely will be part of OnS at some point)
My request:
- Basic explode features
- Easy and full control over explode steps (change order, delete, modify, insert, etc.)
- Easily keep groups or subassemblies non-exploded ie. moving together
- Possibility to render (with Keyshot) exploded models.
- Animations with a LOT of control to be able to create perfect assembly instructions. Run from link in product website / email, no sign in or other requirements for viewer.
- Pause, Notes with pointers, ext. Images and Zooming possibilities for animations.
- Hide other parts and show only next needed parts in animation.
- Combine animations together ie. create main- and sub-animations
- Animations automatically updated if model is changed (self explanatory)
I have done some assembly animations (flash ) with screen recorder and they are decent. But the problem is spending hours and hours on editing and if model changes - do it all again.
For example: LINK (click on 'Laatikon kasausanimaatio' and 'Laatikoston kasausanimaatio'). Don't change language since animation links only appear in Finnish description.
My request:
It has been a couple months since the last post on this thread (and other similar threads). Any new info on exploded views in OnShape? It seems like the best workaround has been creating a copy and moving the parts as you want (no exploded, collapse function), is this still the case?
The QR code or link to explode animation mentioned above seems like a great feature for explaining the assembly process, hopefully we see that come to reality.
There have not been any new features related to exploded view since this thread was active. If you would like to see this implemented please vote on the following improvement request:
https://forum.onshape.com/discussion/1333/exploded-views
If you vote on the request it helps us prioritize our work, and you will be notified when the feature is added to Onshape.
Yes, if a year is not included it means that the comment was from this year.
It sounds like you brought your assembly into another assembly as a subassembly. The mates of a subassembly cannot be suppressed. Instead of inserting your assembly as a subassembly, try inserting them by copying and pasting the part instances from the first assembly to the second. This process is described in this post:
https://forum.onshape.com/discussion/4044/how-to-copy-an-assembly-tab
This will copy all the parts, but none of the mates, so you can freely move the parts into exploded position without suppressing anything afterwards. You may still have some trouble if the original assembly you are trying to explode has subassemblies in it.
This is definitely a workaround, and voting on the improvement request I posted will help us prioritize making a more streamlined assembly explosion.
Let us know if this workflow works for you!
I'm not quite sure what you mean? I have voted the request back when voting came available.
When this post was originally created I think there wasn't separate place for improvement requests in forums.
Many good things has happened since April 2015 but exploded views is not one of those
Twitter: @bradleysauln
