Distance constraint "jumps" to wrong reference.
What is going on here? A blank sketch on the surface of an extrude, I draw a horizontal line, and try to add a distance constraint between that line and an edge of the extrude, or a point of the extrude, but it actually adds a constraint between the line and a totally different unrelated point.
I can't get this to work at all.
Ideas?
https://youtu.be/QrTEWdsPp-o
https://cad.onshape.com/documents/a1911501ae3557d4cac31be2/w/18a90557ea805dbb81feb242/e/693cf120452f66ecc2398504
Ideas?
lana Onshape Employees Posts: 743
@james_sleeman
There is indeed a reference issue introduced by Boolean 3, if you reorder the new sketch to before Boolean 3 you should be able to create the reference you wanted. Wi'll try to fix the issue soon.5
Effectively starting again does not sound like a good solution to me. But maybe I can make some crazy construction lines referenced on the point that wants to steal all the references in order to get to the point that doesn't in some round about way. Pretty unpleasant though.
NB: I'm working on a copy so onshape programmers can see the bug(s) in the original document link posted above if necessary.
