Loft, using a projected line as guide?
lenin_herculeslenin_hercules Member Posts: 5 ✭✭
I have been trying to loft a solid surface, I created a projected line to use as a guide but it simply does not work. I have Pierce every profile but it just highlights red. it works when I make a surface loft but the surface is not smooth in between the profiles.
does anyone know why this happens?
or how to smooth out a surface loft?
    Can you share your document as public? This will give us better info to solve your problem.
  • lenin_herculeslenin_hercules Member Posts: 5 ✭✭
    i can share the document, ill like to keep it private if that's ok
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,912 image
    Hi @lenin_hercules your document will already be public if you are on the public plan. You can always create a cut down version and post the URL for that if you prefer.
