Unable to create drawing from imported part
I have a solidworks part which is not solid. It is just a shell. I presume it is because of not being a solid part? My next question would then be, can I convert the imported part to a solid?
In the meantime you have a couple of options to turn the surface)s) into a solid and then create the drawing:
Use the thicken feature to add thickness to the surface
https://cad.onshape.com/help/#thicken.htm?Highlight=thicken
Use the enclose feature to make a solid from the surface by selecting additional surfaces, solid faces and planes
https://cad.onshape.com/help/#enclose.htm?Highlight=enclose
