creating a drawing
I am trying to create a drawing for an assignment, I have created a document, but when I click on the plus sign and select create a drawing there is a message saying I have no documents, the only choices available to me are the onshape selections. any ideas?
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 223
    Hi Caroline,
    -  Which browser are you using? If you are using Edge or IE, Can you try it out on Chrome, Firefox or Safari.
    - If  all the browsers have the same issue, can you share your document?
    - Does this happen to a specific document or all documents ( if you don't have any, make a copy of a public document and try it out)?
    For reference, here is what I see when I click the + sign
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,845
    Hi @caroline_chamberlain the dialog you are seeing is the drawing template dialog - the parts/assemblies to add to the drawing are done in the next step.
