Dimensioning complex curves
ihor_gernaga
Member Posts: 24 PRO
in Drawings
I'm having trouble finding the right dimensioning tool to measure complex curves. Is there an add on tool or feature that I'm missing?
Thank you.
Thank you.
A trick I use sometimes when things get complex like this is:
Create a sketch and draw a line between the points you want to measure. Then slap a dimension on that line.
