Dimensioning complex curves
ihor_gernagaihor_gernaga Member Posts: 24 PRO
I'm having trouble finding the right dimensioning tool to measure complex curves. Is there an add on tool or feature that I'm missing?
Thank you.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,412
    Can you give an example of what you are trying to measure?
    These are the curves I am trying to measure.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    That may depend on which point on the curve you want to measure from.
    A trick I use sometimes when things get complex like this is:
    Create a sketch and draw a line between the points you want to measure. Then slap a dimension on that line.
    If that is imported geometry and you are trying to find the approx radius, create a sketch like @john_mcclary said and create a 3 point arc over each one using the midpoint of the curve as the third point then measure those.
    Thank you both. I'll give it a try.
