Slower processing
I was working on Gear profile. I imported the gear profile from external sources. The processing of this gear profile taking a lot of time. I have 100mbps net speed, but still, the process is taking longer time. I want to know whether it is a system problem or any other issue.
Remember sketch patterns render slower than feature patterns.
so if you have the entire profile in 1 sketch it will be slow to generate.
But if you only use 1 tooth profile and extrude that, then pattern the extrude it should help the performance.
Most of my slow down is when selecting multiple surfaces from a complex sketch for extrusion.
If your gear profile is an involute have you tried the spur gear feature?
I haven't tried spur gear feature.
