Trying to shell out a part.
wayne_sauder
Member, csevp Posts: 630 PRO
This part will not shell unless unless I reduce wall thickness to 10 thousandth I would like wall to be .125 of a in. How do i get the project on here?
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
In general, for something to shell, the smallest outside radius must be bigger than the shell thickness.
A failure to shell occurs when that outside radius tends to zero.
I say 'in general' as there are algorithms that make this process less sensitive to faces disappearing etc, but they dont always work so its a good idea to know how it works.
If you must have an outside radius that's smaller than the shell thickness, you can try putting those on after the shell.
Other shenanigans are possible, but you would have to share the document
Good luck!
Philip Thomas - Onshape5
Twitter: @bradleysauln
Good luck!
I tend not to use them because of CPU time. I'll offset outer faces and build my own shell. The main reason is regeneration time on deep rebuilds, I don't want to wait. I have found that I'm better at shelling than the shell algorithms. I know this isn't what you want to hear, but its the truth.
Of course, yesterday I used a shell to get something done quickly. I was amazed it worked. In fact I'm always amazed when it works. It's fun to watch.
My point, as your geometry gets more complex, you might be better off building the shell yourself and subtracting it from your part. There will be a day when you might want to try this approach.
