Export Part With Color
wayne_sauderwayne_sauder Member, csevp Posts: 648 PRO
edited September 2017 in Community Support
 Is there a way to export a part in stl. format and it keeps the color you assign to it by editing the appearance? When I export a part that I made green, and then open that file in another program, it always opens in white. Am I doing something wrong?
  • wayne_sauderwayne_sauder Member, csevp Posts: 648 PRO
    Ok, great and thanks for the help.
    No worries.
  • kevin_whitekevin_white Member, csevp Posts: 13 EDU
    edited January 2019
    I am trying to use OnShape with my students for Augmented and Virtual Reality projects. Similarly having issues with color loss. I found the collada export (which is .dae) is working best so far with the Merge Cube viewer for Augmented Reality. However, I am still having issues with using it in CoSpaces.  I really wish OnShape offered an OBJ export option that maintained texture.
  • Rufus31415Rufus31415 Member, Developers Posts: 18 ✭✭
    @kevin_whit, I think you would be interested in this prototype. It is an OnShape viewer for Hololens
  • jim_parentejim_parente Member Posts: 2
    had the same problem, tried different formats; found that "OBJ" kept the color when importing to "Anycubic slicer next"
