New FeatureScript: Full round fillet
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
Hereunder you can find a link to a new FeatureScript to create full rounded fillets.
https://cad.onshape.com/documents/3d52520839c0fa3587798c0f/w/2c36a47f3c428c7a3f8e3a5f/e/d04263a8cc0e773b0f18b0b9
You can test it in two flavors:
- C2C Full Round Fillet (A separated feature to create full round fillets)
- C2C New Fillet (The same feature but integrated with the Onshape's standard fillet feature)
Un saludo,
5
I'd love to see this or something similar incorporated into the standard fillet tool.
You need 2 extra things that you really don't need:
- One more entity selection
- Rotate the view almost all the time so you can select the 3 faces
Try it, I prefer the 2 edges selection ;-)You can see it working in the "custom" standard fillet I have created --> Look at the Part Studio "New Fillet samples"
With this "C2C New Fillet2" feature you can create:
- simple fillets
- variable fillets
- and full fillets
all integrated in a single feature.Eduardo Magdalena C2i Change 2 improve ☑ ¿Por qué no organizamos una reunión online?
Here is a link: https://cad.onshape.com/documents/e5a7756a2e010d30dabb9b8d/w/75d097e96d772acfe6397150/e/4035f83e7948fddd32ea93c6
