Don't copy, it's not a good thing. Syncing doesn't work, never has, don't do it.
I've been running my company off the cloud for 12 years and the thought of a local copy is absurd. I know this is different and we've all been tied to hard-drives since the beginning. You don't want data any where else but the cloud. You login and the data is correct.
We all have to come to grips with this. What we have here is so much better than anything we've had in the past.
Wait and see, you'll like it.
OS, you need to start a campaign:
Print a bunch a t-shirts up and send'm out to everybody.
Or, maybe you should only send them to the believers.
Do you believe? , if you check it, we'll send you a t-shirt.
I should have been in sales,
I have 100/100 connection in my home and office so that area is covered - but what if I spent 50 hours on design and when representing at customer premises my connection fails and I have nothign to show?
But then again what if my computer fails or car or me..
I'm using data connection 90% of the time while on the go, sometimes it's fast sometimes slow.. I rarely use public wlan because everytime I have tried, it's just not working or is slower than mobile network. When abroad I just buy local sim with unlimited data for the time I'm visiting.
For me it would be enough if I could survive with very slow connection every now and then. I don't know anything about programming of OS but if the system would support some sort of special cache which could be turned on while still on good connection and it would 'download' static things to be able to use current version with minimal bandwidth. This would be only for temporary use and local copies would be deleted when turned off. Or maybe it could have another option for updating static stuff everytime when connection is good - for the people who have issues short time every day. Similar to offline maps for navigator. Main idea would be storing the same data locally that would be moved while using so it would be still working on browser and fully compatible with any system.
Most people do this poorly, if at all. I think over time we'll figure out how to collaborate in OS and this will set a new standard for designing a product. This is truly the dawn of a new cad generation and the idea of independent files has been abstracted out of the CAD system totally. I find it interesting that people want'm back.
If we start slicing the cloud data structure into bits, we'll be right back where we are today trying to manage the bits vs. working on a collaborative data structure. Everybody wants to go back to their old localized style which could ruin any chances of a truly collaborative environment.
I would say I'd prohibit any of my team member from branching a bit of my collaborative data set without proving to me that they can successfully merge it back into the main branch without destroying anything. I believe this is beyond most people.
I'd rather people give this 1 data structure a chance to take seed and grow vs. introducing some copy/sync methods prematurely that I believe will never work properly and render us right back were we are today.
My fear is that all the other CAD suppliers with their half-baked cloud solutions will make a big deal out of this non-localized version. They don't have the technology to do a single data structure, this is no reason why we can't have it. Ignore them, they'll be struggling trying to compete with OS's single data structure.
I think we'll have to change our habits. If you do, I believe wonderful things will happen.
Dave
Ariel, WA
Of course there are usb dongles and other options available but if connection is known issue for you, propably OS is not the best solution available.
For most users (including me), OS will most likely provide better security, better backup systems, better collaboration system and I can still export steps and make dvd's to safe box if I feel the need.
In the other hand, after OS has millions of users their servers might be more interesting to hackers than my company. But after they hack the server and copy data, they still need OS to review it and such import progress might be traceable
And another thing, how many ERPs are currently used over network connection? It's just fact for many companies that if you don't have the internet connection working - cad is the minor problem that day.
Just yesterday I played with OS ipad version while on the go, within 600kms trip I didn't bump into any connection problems though my old ipad2 is 'only' 3G (21Mbit/s in theory). I wasn't monitoring the whole trip but tested every now and then and spent couple of hours straight with OS. I'm sure there was also many times 3G dropping to slower connection modes but I didn't notice it in OS.
I think OS will work pretty good with varying connection speeds, designing has a lot of phases where you just turn the model in different views and think of what you should do next and the amount of data to be transferred when finally making a sketch or extrude shouldn't be that much.
If you have your IP on a desktop machine in a secure home or office, make local or encrypted backups and you don't share your IP with anyone else, you are probably pretty secure. If you need to collaborate with others on your IP or have your data on a laptop that moves with you, you may not be as secure as you think. With Onshape, your data is encrypted with SSL/TLS and strong cypher suites before it leaves your browser. It's kept encrypted between the servers that comprise our service. We contract with a professional hacking service that is constantly trying to find new ways of breaking into our service so we can fix them before they are exploited.
We take the protection of your IP very seriously. Onshape employees are forbidden by policy and prevented by technology from looking at your IP unless you explicitly share it with us (via "Share with support").
Your point about internet connectivity is completely true. You cannot access your Onshape files if you don't have a good internet connection. However, this is a little different from having "nothing". Even if you can't access your files right now, they are still there, secure, replicated, backed up and waiting for you and your collaborators to access them. This is quite a bit different from the situation you are in when your hard drive crashes.
You can take a look at some of our security precautions here https://www.onshape.com/security
Thanks
-John
GMail has its Offline mode, so why not On Shape....
As you said previously, the point is that as a user you never know when the idea of a new design will come up to your mind. You may think/brainstorm of a new design while in a plane or in a boat or in a subway, not necessarily open previously in one of your browser tabs, OnShape but you should be able to capture your idea/sketch while not being connected (even if OnS wasn't launched before and still open on your device browser). Some areas in the US has a very limited or no access to Internet via cable/optic fiber or 3G/4G. I experienced it surprisingly few days ago visiting some customers in AR and LA states...
Offline access should be at least narrowed to active private documents which are not shared + new documents. Others could be read-only though.
But when would you download all the documents for offline use? Live sync would propably 'eat' more bandwidth than normal use online and make things worse with slow connection or pay-by-data connection.
If OS would go offline, it should be completely separate workstation version. But I would prefer existing cads (or one good partner) to export/import with OS native files so they could be used offline and easily move models to online cad and back again.
SWCD (formerly SWMC) and SWID (formerly SWIC) CAN run Offline. It has been added to the core functionalities back in October 2014.
Hi Raphael, good to hear from you. Glad that you have made some advancement on that front with the products. I was aware of the offline feature for CATIA, and isn't it true that you still have to do some sort of initialization of offline (i.e. premeditated) before you actually go offline. Anyway, doesn't matter to me because as you know I'm an advocate of cloud but want some kind of capability when my connection is broken or temporarily unavailable.
BTW - when I started this thread 6 months ago and I described my situation on the VTA (light rail like the T or subway) purportedly the 1st free WiFi for public transit in the US - I have given up on it altogether because half the time I cannot connect and when I can connect it takes about 3 minutes to do so with additional EULA confirmation. I have written to them but with no response - when it is a city governmental organization, what do you expect (sorry all you postal workers if I offend) it is cut rate as are many hotels and simply not worth it. Now if I need to do some work on my way in to work, I will tether my iPhone and suck-it-up on my cell usage.
Mark
Onshape is built to live in cloud and I don't think they will put enormous effort to create offline possibility as there are multiple good alternatives on that market.
As for a business case, as things are getting so remote, OS has a huge advantage being cloud based. Cloud native means OS is as flexible as it needs to be to accommodate the changing work environment. But having lived in an area on the "wrong side" of the digital divide, I would not have been able to WFH if my company used onshape and right there you're going scare customers if having fast internet is essential. companies will be at a disadvantage if they have to require employees have reliable internet. An offline mode allows users to work when the need to or can, and transact with the servers when they can.
As an anecdote; I have multiple days a year where we didn't have internet due to weather events. those days would have been lost with onshape.
