How to delete all dangling constraints?
james_mcpherson11762
Member Posts: 26 ✭✭
I'm trying to build some parts libraries from other cad formats. Since Onshape can't import .dxf's I'm importing the 3D models, creating a new sketch, then using the "Use/Project" feature to project the 2D curves onto the sketch. This works (although it is tedious, 2D import into a sketch should exist), however when I then suppress the no-longer needed 3D model, each and every line has a dangling constraint referencing the original 3D model. I end up with hundreds of dangling constraints that I'm currently deleting one at a time... this hurts.
Is there a better way?
-Jim
-Jim
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@James_McPherson11762 I have put in an improvement to project with USE with an option to not add constraints. A constraint manager would be another option and is also in the list for improvements.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
I do mess this dialog from SW and it's capabilities:
Would like to 'use' a previous sketch without the 'use' constraints. Any way to do so?
Alternatively see:https://forum.onshape.com/discussion/comment/60364/#Comment_60364
