Getting a control sketch ready for lofting
pbc
Member Posts: 10 ✭
The vertices in this sketch have all been measured out from a tent I go backpacking with. I'll use the beams featurescript for the metal frame. What I'm trying to figure out is how to model the fabric. I can add more offset planes to add more "interval" data along the Z axis for more X/Y sketches... However i'm not sure how to properly do this so that the loft command will work. Also unsure on pro's/con's of lofting a surface, versus lofting a solid and shelling to something thin, like .015-.025".
https://cad.onshape.com/documents/4ed8e5a088e292239cfd487e/w/daa28ac48fbf9c30f08dba4d/e/5e1eeb49f21bdf3e5e2e826d
I'm getting a really odd "twist" - any ideas?
Edit: I also have a feeling the sculpt face FS will be ultimately be used as well.
https://forum.onshape.com/discussion/5443/loft-twisting
One of the edges was constructed with two lines, while in the other sketch that edge was generated with a singular line. Extra lines = extra vertices.
