Reality Server 3D Rendering
AuroraRon
Member Posts: 141 PRO
Anyone else working with Reality Server for 3D Rendering?
Its driving me a bit crazy. The feed is slow, 1Mb is as good as it get and I wait a long time for stuff to load.
Suppressed components are not hidden and must actually be deleted for it to not show up with you load an assembly in RealityServer - This almost makes it un usable.
There are other issue if it freezing up where it just stop responding but, I think it has some great future here and is easy to use. Just keep saving your work.
Anyone else frustrated with suppressed parts showing up and have any tips on removing them?
Maybe you could branch and delete your unwanted parts on the branch and render here also.
Just to note there is a 'Scene Graph' button which does allow you to hide and show parts without deleting them. It's still tedious if you have gone to the trouble to hide them in your Part Studio I would agree but it is easier than deleting items.
I missed the Scene Graph part. That really helps!!!
I had components behind a glass / window and could not figure out how to access it.
Even though I've been frustrated at times, I'm really loving RealityServer. You've done an amazing job.
It is a very simple app to use and very powerful part of Onshape and the whole online CAD.
On the wish list of features, having images on transparent backgrounds would help so we can put the renders into scenes.
Animated Gifs with the renders rotating would also be really helpful.
Thanks again, If anyone is not using this yet, I think you are really missing out. It really great to be able to bring creations to life.
For transparency, this is on our task list, just a matter of adding PNG output support. Rotatings GIFs isn't something we are likely to add in the near term but there isn't a technical reason it can't be done.
Thanks for the feedback and hopefully the visibility support is helpful for you.
On my list of requests from last time I used it, these may or may not be already available but thought worth mentioning. * Undo, *Copy Material and *save to PNG so you can have a transparent background.
Keep up the good work, its a great app with loads of potential.
Do you have any tutorial on how to make custom material from image and fine tune to correspond with real world?
I'm long time Keyshot user but looking for either web version of Keyshot or alternative with same simplicity and power.
I only tried RealityServer quickly when it was added to Onshape apps, but didn't spend enough time to get impressed. Same happened with Onerender. Few stunning tutorial videos might help with getting started without getting frustrated
https://www.allegorithmic.com/blog/your-smartphone-material-scanner
However this uses their software (which does support the MDL material system we use). When we later add features to allow users to upload their own textures and MDL content this will be a useful method (even before then you might find the article interesting).
Unfortunately there isn't a single click way yet that anyone has to just magically make a material since you need to deal with making it seamless, removing lighting and so on. Allegorithmic have a very good system for that and the mobile Adobe Capture App is said to be adding a feature for automated capture like this some time this year so watch out for that to.
We are working on a much more sophisticated material editing system at the moment but I am afraid until then texturing custom materials is not possible. The large pre-defined library is the interim solution however we of course understand that can't cover every need.
Thanks for the info, I will check the link.
I have got decent results with A3 piece of furniture panel, office scanner, photoshop and keyshot. For me it would be usefull service if I could send piece of material somewhere, pay decent sum and get perfect result into my material library.
http://www.vizoo3d.com/
https://www.muravision.com/
X-rite also have the TAC7 but the scanning aperture is fairly small compared to the above devices. I believe they offer services for scanning though and the accuracy of this device is likely more quantifiable however I have not personally evaluated it.
I cnt get renders above 500K out can you help? All settings seem to give similar outputs?
