Update to Beams Feature
NeilCooke
Moderator, Onshape Employees Posts: 5,933
There is a new update to the Beams feature to fix some bugs and add more profiles. If you have already used version 2.0 of the Beams feature in your Documents, it is recommended that you DO NOT update those existing features to the latest version in case of feature failure.
https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/w/0664d65a957c7bfba7cfbddd/e/bd6831589391741e327fec75
https://forum.onshape.com/discussion/6326/creating-beam-profiles
Once you get the hang of it it's really not hard.
http://www.surdexsteel.com.au/wp-content/uploads/2015/06/Pipe-Tube-products-SHS-RHS-Technical.pdf
Also, are there any plans for cut lists in the pipeline? If so do you know what the timeline is? I am still relying on Solidworks for detailing drawings of weldment drawings.
With regards to cut list a colleague of mine was working on it but did not get it robust enough to release. I can check where he is with it, but I don’t expect anything soon. Please remember that these FeatureScript examples are just that, examples.
At some point in the future this will be made into an official feature so please vote on the improvement request in the category on the right to prioritise it. Thanks.
