Opera Browser - Rotating Around Objects
AuroraRonAuroraRon Member Posts: 137 PRO
edited October 2017 in Community Support
I'm trying Opera Browser instead of Google Chrome in order to keep the browser clean and without plugins - Works much better.
The issue is I can't rotate an object like I do with Google Chrome.(PC)
Right click lets me rotate but it does not stop after letting go of the mouse.  I have to double click to make it let go and than left click to remove the right click menu that shows up.
Anyone know what is happening and how to rotate like with Google Chrome and have it stop when you let go of the mouse?
  • AuroraRonAuroraRon Member Posts: 137 PRO
    BINGO! That was it.  I missed that completely.  OPERA has that on by default. Turn it off and it works.
    Such grief over one little check box.    Thanks everyone !!!
    Hi @AuroraRon ,
    Please file a support ticket by going to the ? menu in the top right corner of a document and pressing "Report a bug".  Sorry you're experiencing this trouble!
    Anyone else using OPERA on a PC?
    Still having this issue.
    Right click on works on everything but rotating parts. If you release the right mouse button, it does not let go.
    If you right click a second time, it brings up a menu.  You have no choice but to right click since left click will just cause it to snap to a new perspective. You must left click after right clicking that brings up the menu you see in my image below, you left click off of it to return the mouse to normal.
    I am using Google Chrome and it works fine.  I just wanted to use another browser since Chrome has a few plug-ins that slow stuff down a bit and I turn and off or on depen Just looking for a clean browser to use just with Onshape, I'll give Firefox a try instead, thanks Neil.
