In sketches, how can I change the colour of my under-defined lines ?
Hello
In my sketches, I am having trouble visually distinguishing between under-defined lines (blue) and full-defined lines (black). How can I change the colour of my under-defined stuff?
Thanks
J
viru Member, Developers Posts: 619 ✭✭✭✭
@john_smith077 , You have to give dimension for conversion from under-defined line (Blue) to fully- defined line (Black). If you do not want to give dimension then apply fix constrain to line then it will convert into black color.
Currently in Onshape user can not change property of line. This is highly requested improvement request raised in forum. You can vote for this request.
7
But that is ridiculous. It's just not all that easy to distinguish between that fairly dark blue and actual black. Edges aren't too bad but vertices can be very difficult. I am still evaluating onshape so voting for things may (or may not!) come later.
EDIT: Btw, exactly how would I go about voting for this request?
Thanks for the feedback! Some other users were having similar troubles and had a discussion about chrome plugins that can change our site to be of higher contrast:
https://forum.onshape.com/discussion/comment/32391
Our improvement requests are located on this forum in the section marked "Improvement Requests". If you go to that section and click "New Idea", you can type in your idea and similar ideas that have already been submitted will pop up. You can either vote on one of these similar issues or if none of these describe your issue well enough, submit your own request.
