comment popup similar to Microsoft Excel comment box please
jeffrey_braggjeffrey_bragg Member Posts: 21 ✭✭
I'd like to see tab comments as well as workbook comments.  I'd also like to see dimensions have the option to add a comment, with the check-mark pop-up allowing the option of a 'caution, comment attached to protect the dimension.  This way in sketches, notes can be added more directly.
    @jeffrey_bragg We are adding more ways to pin to a number of things inside of Onshape but all will be in the comments area.  Today we are keeping all communications at a per workspace/version area.
  • jeffrey_braggjeffrey_bragg Member Posts: 21 ✭✭
    I'm having trouble understanding how this fits comments in a technical drawing or print.  I need to be able to number my dimensions and then legend then at least or add a comment on the drawing to the effect of 'See detail XYZ' in an inset circle.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    In a drawing surely you would just use regular drawing notes that will print with the drawing?
    edited October 2017
    how do you have the text stay the same size as the measurement then?
    meaning as you zoom in and out the measurement stays the same size.
