Latency
in General
I think I have discovered something important. Comcast is sabotaging me! I had cursed latency for a long time not knowing where the fault lay. Now it seems, it's because my Internet connection drops out for a few seconds several times a minute - sometimes longer. If the dropout is long enough, I get assigned a new IP address which causes a number of different programs, including Onshape, to require a new log-in. The connection is so bad, it's hard to get a complete speed-test at DSL Reports.
I called Comcast customer support and got the usual runaround. "It's the customer's fault, of course." " For a fee, we can send out a tech to poke around your equipment to tell you what you are doing wrong." "BTW, can we sell you upgraded TV?" Aaagh!
So, what can I do? The $150 IQ Router claims to constantly reconfigure itself to circumvent at least some cable issues. More importantly, it logs every event related to the connection. I'm told the logs, at least in some cases, can convince Concast to repair/upgrade their lines. I think I'll give it a try.
-John
I'm just thinking of replacing the leased modem with a new IQRouter which is a one year payback. Comcast basically said that if I can't prove it's their fault, then it's my fault. I think the IQRouter logs may be the only way I can get proof.
There's more on the IQRouter. A friend is a Tele-radiologist who works from a home office. His company provides IQRouters because they are specifically designed to handle extremely large graphics files such as x-rays. I wonder if that works with Onshape files.
Is there an Onshape server in Denver - if not, is there any hope of one?
Sorry for all the frustration. Keep working with your ISP to get this resolved.
-John
I pushed on with another complaint to Comcast and their response was typical. "We'll 'roll a truck' to see what's wrong with your equipment - that'll be $70." I refused the "truck" so the customer service person tried pushing TV service. I gave up and called Arris to see if it was something with the modem.
The Arris rep was refreshingly knowledgeable and helpful. He quickly checked modem settings and said that appeared Comcast was 'inhibiting' access to faster channels. He said he thought he could fix that by changing modem settings. In a minute or so he said, "Try that". The connection was noticeably better - so far-so good. He suggested checking back periodically to see if Comcast switched their 'channel inhibition' around.
