Help with a Model and the Shell command
john_gentilin
Member Posts: 15 ✭
With this model, I want to apply the shell command but I had the hardest time making it work. According to this post there was a mention about the smallest outside radius had to be bigger than the shell thickness. So I kept reducing the thickness till the shell command worked.
https://forum.onshape.com/discussion/7191/trying-to-shell-out-a-part
My question is, can someone tell me where my radius are too small, most of my revolves have huge radius's, maybe it's an intersection of two revolves. I would like to have a shell thickness of 2-3mm, and not .3. Here is a link to my model.
https://cad.onshape.com/documents/46fa6561c3c0d839fb353ade/w/c9b9b354f1c329909efc014b/e/c676b3104fc0136db7a1726a
Thank you
-John
Thank you
-John
andy_morris
Moderator, Onshape Employees Posts: 87
Hi John,
The problem is as described in the other post, but your case has some additional challenges. When you create the revolve for the top of the head you create a degenerate point at the outer edges - this where the curvature tends to zero and the tangency to the adjacent faces is hard to resolve.
The shell works far better if you extrude the additional material afterwards, not before the shell, as there are fewer adjacent surfaces. With this change you can create a much thicker shell - I tried up to 1/2 in (12.7mm).
I'd also recommend that you try and shell the simplest shape and then remove the excess material with an extruded or revolve. So at the base I would use a simpler loft with less curvature at the back.
I created an example that I hope will help https://cad.onshape.com/documents/b5ef13232f8d227f5bf0dd03/w/fc4482426570dea0f897266b/e/92c18425ec06b419eaaaff95
Best regards,
AndyAndy Morris / Head of Product Design / Onshape, Inc.7 -
Marc_Miller
Member Posts: 111 ✭✭✭
@john_gentilin The zebra stripes (curvature visualization) can be turned on as one of the "shading" options.
5
Best regards,
Andy
Do you have any pointers to learn more about degenerate points/geometry ? I think I understand your explanation, but need to do some more research. I did notice that the "thicken" command was complaining about that point specifically but the error message just said it could not rebuild the geometry.
Thanks again
-John
