List of Math Operations
Is there a list of valid math expressions and operation such as cos( ), log( ), abs( ), etcetera?
abefeldman Member Posts: 166 ✭✭✭
Also check out https://cad.onshape.com/help/#numeric-fields.htm and expand the "Accepted unit keywords" field.Abe Feldman
UX/PD/Community Support5
https://forum.onshape.com/discussion/7128/a-few-expression-tips#latest
AdivB = (A/B>= 0) ? floor(A/B) : ceil(A/B)
Had a quick look at the Feature Script documentation but not sure which part is relevant.
Found the following but can't see a square function anywhere.
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-using-numeric-fields
You can divide by mm in your expression to cancel the units ((#rise/mm)*(#rise/mm)) which will give you a numerical value, that will get interpreted as a linear dimension (a "length") which is what the Pattern is looking for.
You could also change your Variables to be unitless - then this wouldn't be an issue.
Hope that helps!
