New Public Document - Learn Onshape - Model and Movie - IRIS Shutter
 Darren_A_Henry
                    Onshape Employees Posts: 68
Darren_A_Henry
                    Hi All.  There is a new public document called Learn Onshape - Model and Movie - IRIS Shutter.  In it is a PDF as well as the models with links to two video.  Use RMB click to open the videos in their own tab or windows.
Let me know if you think it is helpful in learning Onshape and how the experience is. All feedback welcome.
Thanks
Darren Henry - Marketing
dhenry@onshape.com
Onshape
Thanks
dhenry@onshape.com
Onshape
It's clean, concise, and focuses on one of the core strengths of OS - the ability to manage top-down and bottom-up simultaneously.
I do have one question though - in a production setting, you can't just "boolean" one part from another, because you need to account for manufacturing tolerances. This fact is really what keeps bottom-up design alive. The world is chock full of "ten thou working clearances", so how do you recommend OS users account for that in this type of workflow?
May I recommend an option in Boolean to account for working tolerances? Ideally, the user would be given a choice to either subtract material from one part, the other, or split the difference. Just a thought...
Linked[in]
Dries
For machined parts it seems like a bit more work than just sketching in the actual dims in the first place (The B-U approach). This also allows for easy tol stacks and "shown/driving dimensions" on drawings. However, since neither of these down-stream capabilities are currently available in OS, the point is moot. "For now"...
Linked[in]
OwS.
