Are there Alignment tools?
ts_2
Member Posts: 22 ✭
Something like.. Align Part A to the center of Part B? Align Center of Part A to Center of front view..etc.. Also choosing what Axis gets aligned. Or is this all done with Mate connector stuff?
I have pieces on my workplane and they are off center of the grid and I can't figure out how to make them look nice.
Optionslougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001@Ts When you are building in a Part Studio, your alignment tools are called constraints. You need to sketch your geometry aligned the way you want and then use Extrude and other 3D tools after. Doing this after you extrude will require you to use Transform which is probably not what you are after.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
I'm guessing though that this is imported geometry? In that case you can translate the bodies (parts) to where you want them to be; though this requires coming up with numbers that work. Instead of that, I would probably hide the Top-Front-Right planes and recreate reference planes off the imported geometry if I could.
LearnOnshape facebook group
