Why is face pattern failing?
bruce_williams
Member, Developers Posts: 842 EDU
Circular Feature pattern works but Face pattern of 3 rib faces returns 'pattern could not be created on the same part'. Linear Face pattern works. I left the failing feature in the document here.
www.accuratepattern.com
john_mcclary
Member, Developers Posts: 4,001 PRO
Yes, @ethan_1 is correct, feature pattern is the correct usage here.
5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Face pattern only works if each instance shares the same faces - in your case, the sides of the block are different.Senior Director, Technical Services, EMEA1 -
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
Alternatively, you can choose to not merge your rib, use a part pattern, and then join the bodies with a boolean. OS seems to lead you away from using feature patterns since it's more costly to rebuild.5
Thank you for your responses. Feature certainly works.
John or anyone - you seem more knowledgeable about the 'correct use' What is the criteria for using Face vs Feature besides what works..
Extra credit @mahir
Thanks!
